yukonone 0 Posted February 17, 2018 I find it odd that a program that takes all its measurements to the inside (sheetrock to sheetrock) but at wall intersections it references the center. Would be great if you could set it to stay with all surface references since these intersections are usually your points where you orient adjoining rooms. Share this post Link to post Share on other sites
yukonone 0 Posted February 17, 2018 Ok, so with further experimentation I get why and have found the work arounds. Share this post Link to post Share on other sites
