ChiefuserMathews
Transfer licence Room Planner
    28287
    pmevans60
    pmevans60
  • Similar Content
    • By C_Parrilla
      All,
      FYI - I'm new to Chief Architect Home Designer 2016 and Room Planner iPad app.
      I created a simple plan (square room with a few wall and base cabinets) on room planner and saved it to the cloud (Green Cloud icon). I closed the app and reopened it to make sure the changes were saved. Then I go over to Home designer 2016 Architectural (Trial) and  -> create a new design -> and go to import and then "Import Room Planner File". I put in my credentials and see the designs I've. The thumbnail that is displayed for all my plans do show the rooms with the cabinets as it does in the iPad app. The issue is that when i select and import the file, I only see the outline of the room but not cabinets. I did a 3D perspective overview but I only see the walls. No cabinets at all. Am I doing something wrong or is this how the import feature is designed to work? Does it matter i'm using the Trial version of Home Designer? I even went ahead and saved a sample plan that was full of cabinets and rooms but same result. Attached are just a few images of what i see. Any other details needed just let me know.
      Thanks in advance for the help everyone.
    • By Doug-o
      What is the consensus with compatibility between air pad 2, room planner and Leica, and if so which Leica?  thanks
    • By ChiefArchitect
      Today we have released the latest update to Room Planner, version 4.3. This update affects both the full version and LE.
      The update includes the following changes:
      Android
      - Fixed an issue that prevented the LG VK815 tablet from downloading content
      - Added support for Bluetooth laser measuring device connectivity on devices running Android 6 (Marshmallow) and Android 7 (Nougat).
      - Added support for Bosch GLM 50 C and GLM 100 C laser measuring devices
      - Improved Bluetooth UI and connectivity
      - Added 'Change Elevation' buttons in Sojourn™ mode
      - Various stability enhancements
      iOS
      - Added support for Bosch GLM 50 C laser measuring devices
    • By dssharp
      Does chief have a windows app for room planner yet? If not  can we plz...plz get one.
    • By ChiefArchitect
      Room Planner 4.1 is now available! Download available for Android or iOS.
      New Features in 4.1
      Change room height Share plans with other users Room schedule Room labels show area or dimensions Toggle display of dimensions, furniture, and annotations Material painter scoping Savable cameras Game controller support Global search in the Library and Material Painter Cancel addition of new objects while dragging Library access in 3D Evenly space openings on a wall Magnifying glass to aid placement of Library objects Floor to top and bottom controls for openings Full screen support
