Sign in to follow this
Lightspeed65
Corrupted geometry due to angled walls
 I created some walls with a 45° relative angle and then tried to modify them, when the geometry seems to have blown up into strange shapes that cannot be erased without crashing the app. Does anyone have any idea how to erase these objects so I don't lose the rest of my plan which includes two other buildings.  Thanks, Dave
Room planner has nothing for exterior measurements at this point, just use pencil and paper for now.
    28283
    nicmac
    nicmac
  • Similar Content
    • By cajunland
      Issue in X12 when using break tool to adjust wall for an extension over a column.
      Bare wall end fir stud and overhead framing stud can be seen in wall section instead of drywall.
      See attached file/pic.
      I do not believe soffit is viable solution as I am seeing that soffits will not frame.
      So framing is important.
      Many thanks to Solver as he addressed this issue and resolved it for my needs by applying different wall types to the wall area drawing. I posted my original files as reference and Solver's solution file (1868954996_MHD_sampletemplateplanSolutionWallEnds).
      And the solution frames out too as can be seen in file with camera Perspective Floor & Perspective Framing views.
      Wall End Issues.plan
      1868954996_MHD_sampletemplateplanSolutionWallEnds.plan
    • By Upward1
      please tell me how to calculate the length of all the walls
    • By ChiefuserMathews
      Is it possible to create a wall type as attached in the image?. This is for a roof top patio partition wall. Could some one guide me please.
      Hello, I am wondering why is the garage foundation wall does not show/appear in the basement (level 0) floor where there is a door above on the first floor? (Plan attached). More over the location I have clouded shows the wall clearly, why it is not displaying at the other locations?
      delete-garage wall.plan
    • By SpeleoWorm
      I have created a number of different wall types to show proper dimensions (i.e. when one side of the wall is 5/8" Type X and the other side is 1/2" drywall) as well as to calculate the correct material counts and to show the proper information in the schedules.  Unfortunately doing that seems to have a down side...it changes the framing as if they were separate walls instead of the same wall with different materials on them.  I have seen the following side effects (colors refer to screenshots below):
      (Green Arrow) In unfinished rooms such as an attic storage space which only has a subfloor but no drywall, the walls get pushed up into the rafters by what appears to be 3". (Red Arrows) The floor joists and top/bottom plates are cut in the middle when they should be continuous pieces of wood.  In addition, you can see that the walls which are produced are not boxed at the end...the top & bottom plates stick out at the end. (Purple Arrow) Parts of the gable wall are not created.  In this case you could argue that it is not needed, but if a builder makes a wall he is not going to leave a hole in it. (Blue Arrows) An extra stud is added to a room that has no drywall, and therefore doesn't need nailer studs.  In addition, it looks like the other stud needed as a nailer for the finished room in the middle is missing from the plan view of the framing (see 2nd screenshot).
      Am I doing this all wrong (creating separate wall types), or is there a way to use them and fix (any of) the issues I mentioned?
      Thanks in advance for any help!
      PS - I am a little surprised that the wall finish is not part of the room settings (like the floor & ceiling already are)...that would allow you to have continuous walls and still have different materials in each room (i.e. greenboard in the bath, 5/8" type X in a garage, unfinished in an attic, etc.
      Example of Wall Issue.plan
