Sign in to follow this
vijayksree
Floor plan disappeared!
When I zoomed out the floor plan disappeared. Not able to view it anymore. Is there a way to manually set X Y Z values that shows at the bottom right of the toolbar?
Try tapping the 2D button. That should refocus the view on the plan.
Ah sounds like you are not using Room Planner. What program are you using?
This forum is used for Room Planner. You can find the Home Designer forum on https://hometalk.chiefarchitect.com.
To answer you question, for Home Designer go to the Window menu and select Fill Window or Fill Window Building Only.
    28290
    Hili3Ddesign
    Hili3Ddesign
