Paint feature freaking out!
For some reason when I try to change colors or texture of various objects it is changing multiple items. For example I tried to change the window trim from white to brown, it changed the toilet, tub and shower to brown as well. On the exterior I tried to change an exterior wall from lap siding to shingles and it changed that wall and a random three other walls.
Any ideas?
In the upper right corner of your Material Chooser you should see a paint spray can, what is the letter currently associated with it? Sounds like you are either in Room {R} or Plan {P} mode. Change it to Component {C} or Object {O} mode. See attached image.
  • 1 month later...
    29799
    Rkey6936
    Rkey6936
