mrscott
Leica E7500i & the Apple
Assumptions: I have the latest IOS on both iPad 2 and iPhone 6s plus and am NOT attempting to connect with Bluetooth FIRST. I am going straight to the Roomplanner APP.
2) My iPad 2 does not see my E7500i in either Roomplanner or Leica's Sketch app so I am suspect there is an issue with the 7500 or my iPad 2.
Thanks,
Steven,
The specs say iPad 2 or newer! What am I missing?
Thanks
  • For Bluetooth lasers:
    • iPad 3 or newer
    • Leica: E7100i (D110), E7500i (D510), D810, S910
    • Bosch GLM 100c
Ah! I see now. Is this a limitation of the the iPad or your software? I have no intention of buying another iPad for this purpose.
It's because of the bluetooth technology on the iPad as well as the hardware on the Leica device.  My guess is that Leica doesn't support the iPad 2, which is why you cannot see it in their own app.  Your phone should work because it has newer technology.
    28287
    pmevans60
    pmevans60
  • Similar Content
    • By KitchenBear
      I can't connect my Leica D110 to use room planner app on an IPad Air 2, just purchased. iPad Bluetooth won't recognize it, but it's is recognized by the Disto app, but room planner won't pick it up. I just spent a LOT of money and requirements says this is supported device, what's up?
    • By mikiefer
      Does anyone no how to reliably pair an iPad 3rd generation with a Leica E7100 for use in Room Planner? When I go into Room Planner and select Bluetooth Devbices it does not appear. It also doesn't appear in my Bluetooth settings area as an available device. Thx
    • By Doug-o
      What is the consensus with compatibility between air pad 2, room planner and Leica, and if so which Leica?  thanks
    • By Athenian_CAD
      Stumbled across this looking for a different article on the Chief Architect site and thought it could help people here.
      KB-02905: Using a Bluetooth Measuring Device with Room Planner
      https://www.chiefarchitect.com/support/article/KB-02905/
    • By BakenUser
      Is anyone using a Samsung Tab S2 with a Disto E7100i? I just got the E7100i to use with Room Planner and I can not get them to play together. The Disto will pair with the S2 and will work with Disto sketch but not with Room Planner. The device shows up in room planner in the measuring device list but when I click on it to activate it nothing happens. I have unpaired & re paired several times, uninstalled Disto sketch, reinstalled Room Planner, rebooted the tablet and still no results. Spent and hour on the phone with Chief tech support and still not working.
      The attached video clip shows what is(n't) happening
      Any suggestions?
      Dave
