Sign in to follow this
QDBHawaii
Transferring from Chief to Room Planner for Client Showcasing
Aloha, and thanks for taking the time to read this.
Looking to see if there is a way to transfer/export already drawn plans from Chief to RoomPlanner
Way looking for a way and couldn't find a opton.
I have only seen the option to IMPORT to Chief
SIDE NOTE:
is there any way to get in contact with NIGEL @ Tech Support? (question to ChiefForum Admin)
Mahalo and Thanks again for reading!
Any ideas?
Again, i see the IMPORT from ROOMPLANNER to ChiefArchitect PC
But.... Not vice versa.
Thanks!
Thank you for your post.
There is no way to take a Chief plan and import it into Room Planner.
awwww ok. Thanks!
Hopefully maybe something to throw in the Suggestion Box then :)
Thanks for the reply sir!
I don't think your devices, other than a MS.Surface, has enough power to do it.
I still don't know how to export from Room Planner to Chief X 7. Can someone help me with this issue?
Tleory:
There should be a tab under the Main "FILE" Tab
Scroll over "FILE">"IMPORT">"IMPORT FROM ROOM PLANNER"
Hope this helps!
Does the same go for Home Designer Pro?  I mean you can only import one way?  Room Planner to Chief Architect/Home Designer?
Yep, you can still only take mobile Room Planner files in to a desktop/laptop Chief Architect or Home Designer.
You can't put the Chief Architect or Home Designer plan back in to the mobile Room Planner app.
    28291
    sarabaayt
    sarabaayt
