Alyssa
Glass, Mirrors, Frames
Has anyone figured out how to create glass?
I am trying to construct a very minimal shower, but I don't see any glass color options, or glass pieces.
Likewise, I do not see any non framed mirrors, am I nuts?
If anyone has a way to get frames off of things, color something glass, or finds a minimal mirror, please let me know!
    28139
    FernaldBuilding
    FernaldBuilding
  • Similar Content
    • By ChiefuserMathews
      Is it possible to create a wall type as attached in the image?. This is for a roof top patio partition wall. Could some one guide me please.
    • By expodesigngroup
      Looking for a designer to handle the soft furnishings side of the business in northern California.
       Are you a brilliant designer with upholstery, bedding, rugs, colors, wallpapers and decorative items?  Do you design cozy and elegant Family Rooms, Foyers, Bedrooms?  Are you a master stager?  Have you wanted to move out of your house with your design business, or wanted to start your own business?  Do you have an existing client base?
      We are located in west San Jose area, with clients throughout San Jose, Campbell and Los Gatos areas.
      Let's talk!  joey@hartsdesigns.com
    • By emaniesanabria
      Hello!
      I'm hoping that someone can help me out here. I frequently use the same materials and I was wondering if there is any way to change the default textures/ colors so that every new project starts off the same. For example: on exterior walls CA defaults to blue lap siding; bathrooms and kitchen default to a cream tile; walls, windows, and doors default to Brite paint; etc.
      I'd like to change these so that I can save myself time. Can someone explain how to do that, please?
      Thank you!
    • By DonSpring
      How do I take picure of a color or texture and use it in Room Planner as a custom material?
    • By MarkMc
      Short story-here is a 3 wire tray base pullout representing a Hafele 546.62.826 with 546.63.114 (set and a half)
      two cabinets and the insert.
      Base width is 14" but can resize that-height is set for a frameless cabinet that with 4" toe kicks but you can copy it in your library and resize for others. If you want two baskets well you will have to work on that yourself (I have wooden things made by the mfg)
      Long version if you care
      Melissa was placing a wire pullout in a base cabinet and ended up using one meant for a tall cabinet. The only wire 3 tray PO that I know of is from Hafele-a few widths are available and the height is adjustable but you can't go and (reasonably) get a custom wire P.O. Some of the Hafele catalog is available in 2020 BUT not in Chief. (get after your Hafele rep and cabinet suppliers to change that). You can export a 3d DWG from 2020 but still have to get textures onto it-ugh. Hafele now has a 3D database which is awful to rummage through and the face counts get atrocious. Anyway-. being unable to resist a rabbit hole and to escape playing with Ruby and paperwork I put this together. Just needed a break.
      Base PO cabinet.plan
