KitchenBear
iOS on IPad Air2, can't connect Leica D110 laser measure. Works in Disto app, but not room planner
I can't connect my Leica D110 to use room planner app on an IPad Air 2, just purchased. iPad Bluetooth won't recognize it, but it's is recognized by the Disto app, but room planner won't pick it up. I just spent a LOT of money and requirements says this is supported device, what's up?
Please share if this is resolved
I want to purchase this laser and it would be helpful to know it works for sure before I purchase
Thanks
Please give us a call at your earliest convenience so we can assist you with this. We can be reached at (208) 665-3674 or toll-free at (800) 482-4433.
THANKS SO MUCH!
problem resolved. Online support had me to a soft boot of Ipad and after powering back on it was directly recognized by the Room Planner app.
okay, three of us have been trouble shooting this problem. Reading the forum and nothing. The DISTO Sketch app is functional, but Room Planner does not recognize any device. We're at an end and it seems to be a Room Planner issue.
After an hour and a half with three of us I finally found a fix. I already had purchased the Room planner app, and did everything including soft boots with no results. As a last ditch effort I downloaded the free version of Room planner and it magically permitted by Leica E7100i to read into the Room planner (paid version). Go figure. someone in the software dept. needs to wake up. Us novices have limits to what we will put up with.
Just purchased Room planer. At the beginning, it did not want to connect to my Leica 7500i. After several restarts it finally did connect. How do I read measurements from it to Room Planer?
    28287
    pmevans60
    pmevans60
  • Similar Content
    • By mikiefer
      Does anyone no how to reliably pair an iPad 3rd generation with a Leica E7100 for use in Room Planner? When I go into Room Planner and select Bluetooth Devbices it does not appear. It also doesn't appear in my Bluetooth settings area as an available device. Thx
    • By Doug-o
      What is the consensus with compatibility between air pad 2, room planner and Leica, and if so which Leica?  thanks
    • By mrscott
      Assumptions: I have the latest IOS on both iPad 2 and iPhone 6s plus and am NOT attempting to connect with Bluetooth FIRST. I am going straight to the Roomplanner APP.
      2) My iPad 2 does not see my E7500i in either Roomplanner or Leica's Sketch app so I am suspect there is an issue with the 7500 or my iPad 2.
      Thanks,
    • By Athenian_CAD
      Stumbled across this looking for a different article on the Chief Architect site and thought it could help people here.
      KB-02905: Using a Bluetooth Measuring Device with Room Planner
      https://www.chiefarchitect.com/support/article/KB-02905/
    • By BakenUser
      Is anyone using a Samsung Tab S2 with a Disto E7100i? I just got the E7100i to use with Room Planner and I can not get them to play together. The Disto will pair with the S2 and will work with Disto sketch but not with Room Planner. The device shows up in room planner in the measuring device list but when I click on it to activate it nothing happens. I have unpaired & re paired several times, uninstalled Disto sketch, reinstalled Room Planner, rebooted the tablet and still no results. Spent and hour on the phone with Chief tech support and still not working.
      The attached video clip shows what is(n't) happening
      Any suggestions?
      Dave
