Import to Home Designer ... no Cabinets
All,
FYI - I'm new to Chief Architect Home Designer 2016 and Room Planner iPad app.
I created a simple plan (square room with a few wall and base cabinets) on room planner and saved it to the cloud (Green Cloud icon). I closed the app and reopened it to make sure the changes were saved. Then I go over to Home designer 2016 Architectural (Trial) and  -> create a new design -> and go to import and then "Import Room Planner File". I put in my credentials and see the designs I've. The thumbnail that is displayed for all my plans do show the rooms with the cabinets as it does in the iPad app. The issue is that when i select and import the file, I only see the outline of the room but not cabinets. I did a 3D perspective overview but I only see the walls. No cabinets at all. Am I doing something wrong or is this how the import feature is designed to work? Does it matter i'm using the Trial version of Home Designer? I even went ahead and saved a sample plan that was full of cabinets and rooms but same result. Attached are just a few images of what i see. Any other details needed just let me know.
Thanks in advance for the help everyone.
Turns out the import from Room Planner iPad app is working as expected. I opened up a case with tech support and they confirmed. View info below.
"When you click on a file to import into Home Designer, however, only the walls, windows and doors are imported.
This occurs because the cabinets, furniture, accessories, and other 3D items between the two software packages (Home Designer & Room Planner) are different. The items within Home Designer have more surfaces thus producing greater detail when taking 3D views. With a mobile app, such as Room Planner, we try to keep the surface count lower on many of our items, thus sacrificing detail for performance."
  • 4 months later...
Might I suggest to programmers that there are two blocks made of each cabinet, appliance and furniture then? One for RP and one for CA, one low res and one higher res.  Just the basics that come with the standard Planner program, no downloadables.   So they can be imported with the design into CA and just get swapped out with the higher res items.  We can then swap them out with what we really want for the final drawings.  I think we would all be pretty happy with how Room Planner works with CA then.  Right now it's just a As-Built wall, door and window sketcher for those of us using CA.
  • Like 2
  • 2 years later...
I completely agree to this suggestion. I would like to use the RP as a remodeler to also include the current cabinet layout so when I get back to the office to start using CA not only my walls pull in but the cabinets as well.
    29799
    Rkey6936
    Rkey6936
  • Similar Content
    • By norryboy
      Has anyone else experienced cabinet reveals changing from X12 to X13? I have attached images from an identical plan that was created in X12 from a cabinet library I created. The X12 shows as I would expect. X13 shows as expected as well. The difference starts when inserting cabinets from the library I created into X13.
      Chief has changed/added some default settings. The overlays in X12 are in the Box Construction section of the defaults. The overlays in X13 are in the Drawer Face Item Specification.
      The cabinet in X13 had the overlay changed form the default 3/4" from X12 to 1/16" when inserted into X13. I'm guessing it's because the overlay defaults have been moved to the Drawer/Door face item specification.
      I really don't want to have to redo the entire cabinet library as there are hundreds of them. The reason the library was created is due to our cabinet supplier having specific cabinet callouts.
      Thank you for any help.
    • By toucanskeleton
      I'm trying to replicate a window sill I have on a model in SketchUp. I can import a .SKP file and convert it to a 3D symbol just fine, but then in elevation views, CA wants to show these CAD lines every couple inches for some reason. The 3D view looks just fine, but I do need to be able to create elevation views as well. Is there some checkbox I could toggle and solve this issue?
    • By MarkMc
      Updated 2/28-added cabinet doors into schedule-one on it's own floating and example of it on a cabinet.
      Changed the corbel procedure-instead of specifying the symbol should be "inside" the cabinet I now embed the "holding cabinet" into where the corbel goes. This allows proper vector and watercolor views. Revised plan attached
      I finally found a way to get millwork into the cabinet schedule without using architectural blocks. Problem with blocks is the dimensions read based on orientation in the space and not on the object.
      It's a bit of a futz at first but I'm happy. Once set up the stuff can live in the library.
      Place the millwork in a new plan, convert to symbol _CABINET DOOR instead of millwork. You will have to work with the origin and stretch zones. Origin will vary if it is going in as inset or trad overlay.
      Then place a cabinet, futx with the dbx (most need to have opening for back and both sides) In 3d vector view I change the sides of the cabinet to "opening no material"
      Once cabinet is done save to library- can later add a different millwork door to it to save work.
      Plan shows a schedule, two millwork "doors" and a couple of cabinets using them for reference. Open all dbxs to get the idea. (no not doing a video)
      I also placed at the bottom of the plan what I've been doing to get moldings, loose accessories, touch up kits, toe kick etc into the cabinet schedule. These are also saved to the library for reuse.
      The Text callout is placed once and copied. Dimensions can be adjust to read properly but the quantities are off so I put that into the label.
      Bracket sch.plan
    • By MarkMc
      I received a couple of question from folks at and after yesterdays GTM I'm attaching a plan and a layout in a zip file. Consider this something for forensic examination-to use to figure out how you want ot go about things. There are very likely mistakes, I'm certain that some of the label macros need work and in the course of putting this together some unwanted ones may have dropped in from the library..
      There was a request at the meeting for annosets. I agree with Perry and Scott that you need to put together what works for you but this may help get you going. The annosets here are a recent update to mine and may have mistakes yet. Started with something, a year or so later updated it, learned some more, fudged it as I went, now going working on a new and improved revised set. No you do NOT need to change annosets with every release. Yes you can use the same annosets for multiple templates (reference manual). OR you can use different ones. It's a good idea to export them somewhere (like the CA data file) with a date associated for when you muck them up or need to go back or want them somewhere else. I keep a second set that is less used for new construction that is different than my everyday remodel set. Just cuts down on the clutter.
      Label macros included- the principal I'm working with is to use one macro while I work so I know what is going on, then to change all the cabinets on the primary layers to have another macro that works for ordering nomenclature (3 inch increments for example) To get any of the macros out you open the macro management dbx pick it and export- then do the reverse in another plan and import (HIT F1)
      There was a question about the molding warehouse- included some in one room with a note. Don't forget to play with the new drag a profile from the library feature.
      Countertops-no chief will not automatically label finished edges- see the plan, keep some text int there and copy and paste. (maybe someone from the dark side can write a macro for that but I'm not going there.) A few ways to get millwork and other things into a schedule- included one arch block turned sideways to show the problem from using them. couple of odd symbols thingies for the schedules. Included-an architectural block with a wood hood and a blower insert inside it. The blower insert is currently set so you can't really resize it without going into the symnbol DBX and changing things (look in the reference manual and play with it -best way to learn) You can use this to see if the blower you want will fit in the hood the client wants. Glass house view, cross section slider, backclipped elevations. Odds and ends-if you have not seen Scott Harris method of globally changing kitchen cabinets you should check it out. Basically he keeps a couple of cabinets on the side in different door/color/construction. Then picks one and sets as default  (one reason I ONLY use cabinets that respect the defaults even though some things don't AND naturally changing from overlay to inset requires some heavy redesign) There was a mention that 2020 will underline a label if you alter the size of a cabinet from the default. Chief won't. Thing is that 2020 will also underline the label if you add an accessory or a modification to the cabinet so it is NOT saving you from yourself (unless you do those last) File and layout attached, neither is complete, but worth fooling with I think.
    • By jbonja
      Is there a way to pass data into CA via the variables from other programs?  Specifically I want to populate my client information automatically from a client database I have versus re-typing.
      Thanks
