Sign in to follow this
liveatul
Insert pictures from camera photo library.
How can I import images from my iPad photo library? And use as a new object or use in photo frames as a patterns.
Pl. update
Pl. update
This is a great suggestion and one that we would really like to implement into Room Planner in the near future. If you own one of our Home Designer or Chief Architect products (MAC/PC), you can import your Room Planner file along with your own custom images to use as materials for picture frames, computer monitors, etc.
Here are a few helpful links on how to import RP plans and custom materials into Home Designer:
http://www.homedesignersoftware.com/support/article/KB-02302/286/Home-Designer/Import-Export/Importing-a-Room-Planner-Design-into-Chief-Architect-and-Home-Designer.html
http://www.homedesignersoftware.com/support/article/KB-00138/
    28281
    New2Chief
    New2Chief
  • Similar Content
    • By ChiefuserMathews
      how can I add custom notes to the library so that I can use in other layouts
    • By KTKArch
      (x11) When I open an object to fill (closed polyline etc) I have a standard list and the library option that takes me to Chief's library. It currently only shows that I have patterns of my own making in User Library. It also appears that I can no longer open 3rd party .pat files as I could in earlier versions. And finally, I cannot find a basic EARTH pattern in the defaults. So either I somehow purged some of the patterns or there isn't a default EARTH pattern. And how can I import my earlier .pat files? Not sure if this happened after installing x12 or if it is just this one file. Not using x11 but to finish out this project.
    • By WannabeDesign
      Working in Windows 10 on a surface pro laptop. All updates for Chief Architect Home Designer Architectural 2020 have been installed.
      The library keeps freezing me out of my plan when I type a 2nd search in the search bar of the library browser. I can see the cursor out of the plan window but can't do anything but save and close the program to start again. This is very annoying having to start and close the program continuously. Are there any fixes for this?
    • By Renerabbitt
      POST 0
      You've found it! A thread offering up some of my favorite symbols and content for Chief Architect X-11.
      These items are for X-11 only. If you haven't updated yet I encourage you to do so, it's a great release.
      The following content is listed by category with both a link to the post within this thread for easy navigation and a link to a direct download if you won't to cut straight to the chase. new/recent uploads are in RED font
      CLICK ON THE "DL" FOR INSTANT .CALIBZ DOWNLOAD:
      CONSTRUCTION ASSEMBLIES/ARCHITECTURAL ITEMS:
      RABS 42 CABLE RAILING - DL    RABS MODERN FRONT DOOR AND DOOR ASSEMBLY - DL   RABS INTEGRATED SINK - DL NEW!!! 03/26/2020
      ENTOURAGE:
      RABS CHARLES-HILL GROUPED LIVING ROOM - DL RABS CHELTON GROUPED LIVING ROOM - DL    ACCESSORY HOME #1 - DL ACCESSORY HOME #2 - DL ACCESSORY HOME #3 - DL
      KITCHEN RELATED:
      3-ISLANDS - DL LA CORNUE 1908 RANGE - DL CAFE APPLIANCES, PAINTABLE(CORRECTED) - DL
      LIGHTING:
      PENDANTS AND SCONCES - DL-1 - DL-2 - DL-3 - DL-4 RECESSED NC HALO 4 INCH LED WITH HOUSING - DL NEW!! 03-22-20
      MATERIALS:
      TILE AND COUNTERTOPS #1 - DL 1(ONEDRIVE LINK) - DL-2 CUSTOM WHITES WITH PAINT TOOLBAR ICONS - DL-1 - DL-2 - DL-3 - DL-4 - DL-5 - DL-6 RABS RUGS 1V1 - DL          RABS STARTER KITCHEN MATERIALS PACK - DL         RABS FLOORING PACK 1 - DL            RABS OLD GOLDEN OAK FLOOR - DL
      SYMBOLS:
      FIREPLACE ASSEMBLY 1 - DL     ACKLES BED AND EDISON TABLE LAMP - DL-1 - DL - 2 TEAPOT MATERIAL EDITOR REPLACEMENT - DL-1 - DL-2 FINMARK TABLE FROM CB2 - DL FIREPLACE MANTLES 1 AND 2 - DL    RABS STRETCHABLE PICTURE FRAMES - DL
      VIDEOS:
      YouTube Channel
      Many of these I have personally made or modified. Some of the content may have been created by others for which I will give credit. Many of the materials have free licensing, so no credit is needed.
      Some of this content may slow down your program as I have a high powered machine and often times use complex and high resolution textures. I will try and give as much detail as possible. Use at your own peril!
      No but seriously dig through and enjoy, I've spent a good number of hours ensuring the quality of these symbols and will update them periodically- so CHECK BACK IN! and PLEASE GIVE A LIKE FOR THE POST OF ANY SYMBOL YOU LIKE, IT ENCOURAGES ME TO GO BACK AND REFINE/REDUCE/OPTIMIZE THAT SYMBOL. GIVE A DOWNVOTE AND IT'LL PROBABLY ENCOURAGE ME TO DO THE SAME THING...YOU'LL JUST BE A JERK FOR IT
      CHANGELOG:(PACIFIC TZ)
      Page 1:
        Post 0:
      02-12-2019- 4:45PM: Removed the poll, migrated this thread. re-uploaded from X11 public beta 02-20-2019-2:59PM: Added a Poll for user content requests 03-30-2020-6:49PM: Deleted Video Links and added link to YouTube Channel   Post 5:
      02-12-2019- 4:45PM: centered the hearth on the symbol   Post 18:
      02-12-2019-9:52PM: Posted and fixed DL links
      Here is a symbol to get you started:
      @Cheryl_C_Crane Think you requested this,
      RUSTIC BRICK 2.calibz
      Number of Textures: 2
      Map size: 1024x1024
      Filesize: 3.13 MB
    • By Alyssa5
      Hi,
      I have attached a couple of screenshots to best describe my problem
      Whenever I move the camera view, I get this sort of distort colouring on my walls?
      Any ideas what's causing this?
      Thanks
