cascadepixels
Metric dimensions?
Found it. Settings | Dimensions | Units.
However, entering dimensions is tedious because it is necessary to manually clear the existing dimension first, and then enter the new value, not forgetting to enter the unit of measurement as well eg: 2.34m
May I suggest that the original measurement be preselected, so that typing anything immediately replaces the old value; or display nothing and then replace the value when Enter is pressed.
Also, please make the unit of measurement default to what I have selected in Settings.
    28292
    DJRobinson13
    DJRobinson13
  • Similar Content
    • By Designer100
      Hi,
           I am trying to place columns and grid line with dimensions.
      I have to create on column circles and columns lines , then the dimensions will not place correctly to center usining manunel dimensinos (its leaves 12in on each side of column center lines.
      Chief Architect needs to be more friendly and have more commercial symbols and column lines to dimensions to them. They do have a commercial templet, but it does not have any of those.
      Plus they need commercial window details etc. I am donating this for a non-profit to design a rendering and another area added on the back of this building.I am donating a rendering of exterior to help them fund raise $300.000.00 (by December) to buy the exist. building and remodel adding finishes to look better and another 2,000 s.f. to it.
      Can anyone help me on working out the Grid center lines and will measuring correctly? turn on background and existing bldg. is under neath.
      Thanks,
      Newell
      CA Premier x 12
      Porter Road Floor Plan existing.PDF
      Existing Building remodeling.Addition.plan
    • By sascea
      Does anyone know how to change the decimal under the story pole marker lines? I've attached a picture, it's the numbers circled in orange. I would like to get rid of them completely as some of my story pole markers are close together and this takes up extra space.
      Thank you in advance!!
    • By TCDLLC
      Hi, I am a Revit user converting to Chief.
      When working with angled walls in Chief, I have not been able to lock a wall from moving when changing dimensions on connecting walls.
      I am familiar with how to use the directional tools to move an end of an object to adjust its dimensions.
      When angled walls are off-angle, I can waste significant time adjusting the lengths of the angled walls and still not achieve the dimensions I need for all connecting walls.
      The use case scenario is when I am drafting a plan using dimensions provided to me to create the build.
      Of course, if I was creating a plan from scratch, I could probably avoid this situation.
      Any suggestions?
    • By wjmdes
      Not sure if this was an issue in X11, but in X12, I added "FIELD VERIFY" to Trailing Text under Segments and it also added "FIELD VERIFY" into the extension next to the elevation.  Fortunately, in this case, that is fine, but maybe an issue in the future.
    • By Chiefusermickey
      Is there any way to force new objects such as a window, wall, or door to snap to the grid? I have my snap grid/snap unit set to 1". I would like for new items to be placed in the plan on a whole inch and not fractions. As it is I can drop in an object and the dimensions to it will be off the grid and not a whole number. I have to manually move the object to get the dimension to a whole number. I have attached an example of my problem. To many unwanted fractions.
