jsphillips33
Tile Shower Walls and Tile Shower Pan
Can you make a shower with tile walls?  Can you make a shower with a tile shower pan?  Can you add shower faucets to the walls?  Can you design a tile pattern on the walls or floors?
    28302
    ShanePDX
    ShanePDX
  • Similar Content
    • By ChiefuserMathews
      Is there an option in CA if I want to layout a patio tile with border?
    • By Renerabbitt
      POST 0
      You've found it! A thread offering up some of my favorite symbols and content for Chief Architect X-11.
      These items are for X-11 only. If you haven't updated yet I encourage you to do so, it's a great release.
      The following content is listed by category with both a link to the post within this thread for easy navigation and a link to a direct download if you won't to cut straight to the chase. new/recent uploads are in RED font
      CLICK ON THE "DL" FOR INSTANT .CALIBZ DOWNLOAD:
      CONSTRUCTION ASSEMBLIES/ARCHITECTURAL ITEMS:
      RABS 42 CABLE RAILING - DL    RABS MODERN FRONT DOOR AND DOOR ASSEMBLY - DL   RABS INTEGRATED SINK - DL NEW!!! 03/26/2020
      ENTOURAGE:
      RABS CHARLES-HILL GROUPED LIVING ROOM - DL RABS CHELTON GROUPED LIVING ROOM - DL    ACCESSORY HOME #1 - DL ACCESSORY HOME #2 - DL ACCESSORY HOME #3 - DL
      KITCHEN RELATED:
      3-ISLANDS - DL LA CORNUE 1908 RANGE - DL CAFE APPLIANCES, PAINTABLE(CORRECTED) - DL
      LIGHTING:
      PENDANTS AND SCONCES - DL-1 - DL-2 - DL-3 - DL-4 RECESSED NC HALO 4 INCH LED WITH HOUSING - DL NEW!! 03-22-20
      MATERIALS:
      TILE AND COUNTERTOPS #1 - DL 1(ONEDRIVE LINK) - DL-2 CUSTOM WHITES WITH PAINT TOOLBAR ICONS - DL-1 - DL-2 - DL-3 - DL-4 - DL-5 - DL-6 RABS RUGS 1V1 - DL          RABS STARTER KITCHEN MATERIALS PACK - DL         RABS FLOORING PACK 1 - DL            RABS OLD GOLDEN OAK FLOOR - DL
      SYMBOLS:
      FIREPLACE ASSEMBLY 1 - DL     ACKLES BED AND EDISON TABLE LAMP - DL-1 - DL - 2 TEAPOT MATERIAL EDITOR REPLACEMENT - DL-1 - DL-2 FINMARK TABLE FROM CB2 - DL FIREPLACE MANTLES 1 AND 2 - DL    RABS STRETCHABLE PICTURE FRAMES - DL
      VIDEOS:
      YouTube Channel
      Many of these I have personally made or modified. Some of the content may have been created by others for which I will give credit. Many of the materials have free licensing, so no credit is needed.
      Some of this content may slow down your program as I have a high powered machine and often times use complex and high resolution textures. I will try and give as much detail as possible. Use at your own peril!
      No but seriously dig through and enjoy, I've spent a good number of hours ensuring the quality of these symbols and will update them periodically- so CHECK BACK IN! and PLEASE GIVE A LIKE FOR THE POST OF ANY SYMBOL YOU LIKE, IT ENCOURAGES ME TO GO BACK AND REFINE/REDUCE/OPTIMIZE THAT SYMBOL. GIVE A DOWNVOTE AND IT'LL PROBABLY ENCOURAGE ME TO DO THE SAME THING...YOU'LL JUST BE A JERK FOR IT
      CHANGELOG:(PACIFIC TZ)
      Page 1:
        Post 0:
      02-12-2019- 4:45PM: Removed the poll, migrated this thread. re-uploaded from X11 public beta 02-20-2019-2:59PM: Added a Poll for user content requests 03-30-2020-6:49PM: Deleted Video Links and added link to YouTube Channel   Post 5:
      02-12-2019- 4:45PM: centered the hearth on the symbol   Post 18:
      02-12-2019-9:52PM: Posted and fixed DL links
      Here is a symbol to get you started:
      @Cheryl_C_Crane Think you requested this,
      RUSTIC BRICK 2.calibz
      Number of Textures: 2
      Map size: 1024x1024
      Filesize: 3.13 MB
    • By stacimunic
      Hello,
      I am very new to Chief Architect and I am trying to find the best way to create a shower dam (the short 3" wall on the floor of a shower that prevents the water from escaping out of the shower), This wall will also hold the glass walls and doors that the user will access the shower from. Is that created by doing a pony wall, with a 3" lower half or is there a better and easier way to create this?
      NOTE: I am using version x11 Interiors (not the PRO version)
    • By carowe
      Is there a way to download a picture of a tile from a manufacturer's website and create a material?  I am trying to use the attached pics of tiles for a backsplash in a kitchen and have followed the instructions on the videos, but cannot get the tile to align properly.  I have attached pictures of the two tiles I'd like to show the client, and a picture of what happens when I try to use the material.
      Thanks!
    • By MN_JohnH
      I am wondering if there is a simple way of aligning the custom tile in a custom backplash? In the attached drawing I have created two custom tiles for this hypothetical shower. The big tile is 24x24 and I would like to have it go 5' up on the wall and then have a 12" deco strip of 2x2 tile and then more of the larger tile above that to the ceiling. Problem is I want a full tile on the top of the 5' high lower part, (the half cut would be on the bottom), and then start with a full tile on top of the deco strip. And my deco strip is 2x2 tile, I made it as a 12x12 square of 2x2 tile and yet it doesn't line up as full tile on the top and bottom edges...
      Tile alignment.plan
