Sign in to follow this
zezeon
cannot save to cloud!!
I cannot save my room planner file to cloud.
I already made an account. And, loogged in.
But when I try saving file to cloud, just waiting icon appears and does not complete the task.
What's wrong?
What's wrong?
Hi zezeon,
Do you have a reliable Wi-Fi connection on your iPad while you're uploading to the Cloud? If so, what happens if you log out of your Cloud Account, log back in, and then attempt to upload a plan? You may also try closing the application completely as per the steps below and retry.
- Click on the 'Home' button on your iPad.
- This should return you to the iPad Home Screen.
- Once you are at the Home Screen, double-tap on the Home Button.
- The Room Planner icon will appear in the list of open applications at the bottom of the screen.
- Place your finger over the preview image being displayed above the Room Planner application icon and swipe up to completely close it.
- Once Room Planner has been closed, press the Room Planner icon on the Home Screen again to launch it.
Thanks for reply. I tried as you recommended. But even when I restart the app or reboot iPAD, I see the wait icon still going on. So, when I open the 'saved plan' of file menu, I just see that wait icon and I cannot do anything about file management. Still saving to cloud? This is odd.
Hi Zezeon,
Would it be possible for you to update via the App Store to the newest version of Room Planner (3.0) which was released yesterday evening? Once you have updated to 3.0, you will need to log out of your Cloud account (Settings> Cloud> Log Out) and log back in. Please let me know your results.
I successfully saved to cloud by your method. I have 2 iPADs. But, while it appears to be saved to cloud in my first iPad, the other iPad( logged in with the same ID )does not have that file I saved in first iPad.(I logged out and in.)
Second iPad used no space while my first used up 11%.
Did you update both of your iPads to Room Planner 3.0? If not, you will need to do so for the plans to be interchangeable. Plans that have been opened or edited in 3.0 can not be used in an older version of Room Planner such as 2.0.
Of course I updated..
Hi Zezeon,
If you do not see the plans on your second device even though you are logged into the same Cloud account on both iPads, then poor internet connectivity on the second iPad may be to blame. The best thing to do in this case is to go to a ‘3D’ view and then back to ‘2D’ (which refreshes the scouts that look for plans, thus syncing the plans to the iPad). Alternatively, logging out and logging back in on the device that is not seeing the plans should also remedy the issue.
If you continue to have trouble, you may want to move your iPads closer to your wireless router to allow for a stronger internet connection.
Due to unknown reason, the saved plan appeared in the cloud now.
Maybe some internet problem or hacking?
Thanks for your kind and persevering guides.
    28291
    sarabaayt
    sarabaayt
  • Similar Content
    • By Renerabbitt
      POST 0
      You've found it! A thread offering up some of my favorite symbols and content for Chief Architect X-11.
      These items are for X-11 only. If you haven't updated yet I encourage you to do so, it's a great release.
      The following content is listed by category with both a link to the post within this thread for easy navigation and a link to a direct download if you won't to cut straight to the chase. new/recent uploads are in RED font
      CLICK ON THE "DL" FOR INSTANT .CALIBZ DOWNLOAD:
      CONSTRUCTION ASSEMBLIES/ARCHITECTURAL ITEMS:
      RABS 42 CABLE RAILING - DL    RABS MODERN FRONT DOOR AND DOOR ASSEMBLY - DL   RABS INTEGRATED SINK - DL NEW!!! 03/26/2020
      ENTOURAGE:
      RABS CHARLES-HILL GROUPED LIVING ROOM - DL RABS CHELTON GROUPED LIVING ROOM - DL    ACCESSORY HOME #1 - DL ACCESSORY HOME #2 - DL ACCESSORY HOME #3 - DL
      KITCHEN RELATED:
      3-ISLANDS - DL LA CORNUE 1908 RANGE - DL CAFE APPLIANCES, PAINTABLE(CORRECTED) - DL
      LIGHTING:
      PENDANTS AND SCONCES - DL-1 - DL-2 - DL-3 - DL-4 RECESSED NC HALO 4 INCH LED WITH HOUSING - DL NEW!! 03-22-20
      MATERIALS:
      TILE AND COUNTERTOPS #1 - DL 1(ONEDRIVE LINK) - DL-2 CUSTOM WHITES WITH PAINT TOOLBAR ICONS - DL-1 - DL-2 - DL-3 - DL-4 - DL-5 - DL-6 RABS RUGS 1V1 - DL          RABS STARTER KITCHEN MATERIALS PACK - DL         RABS FLOORING PACK 1 - DL            RABS OLD GOLDEN OAK FLOOR - DL
      SYMBOLS:
      FIREPLACE ASSEMBLY 1 - DL     ACKLES BED AND EDISON TABLE LAMP - DL-1 - DL - 2 TEAPOT MATERIAL EDITOR REPLACEMENT - DL-1 - DL-2 FINMARK TABLE FROM CB2 - DL FIREPLACE MANTLES 1 AND 2 - DL    RABS STRETCHABLE PICTURE FRAMES - DL
      VIDEOS:
      YouTube Channel
      Many of these I have personally made or modified. Some of the content may have been created by others for which I will give credit. Many of the materials have free licensing, so no credit is needed.
      Some of this content may slow down your program as I have a high powered machine and often times use complex and high resolution textures. I will try and give as much detail as possible. Use at your own peril!
      No but seriously dig through and enjoy, I've spent a good number of hours ensuring the quality of these symbols and will update them periodically- so CHECK BACK IN! and PLEASE GIVE A LIKE FOR THE POST OF ANY SYMBOL YOU LIKE, IT ENCOURAGES ME TO GO BACK AND REFINE/REDUCE/OPTIMIZE THAT SYMBOL. GIVE A DOWNVOTE AND IT'LL PROBABLY ENCOURAGE ME TO DO THE SAME THING...YOU'LL JUST BE A JERK FOR IT
      CHANGELOG:(PACIFIC TZ)
      Page 1:
        Post 0:
      02-12-2019- 4:45PM: Removed the poll, migrated this thread. re-uploaded from X11 public beta 02-20-2019-2:59PM: Added a Poll for user content requests 03-30-2020-6:49PM: Deleted Video Links and added link to YouTube Channel   Post 5:
      02-12-2019- 4:45PM: centered the hearth on the symbol   Post 18:
      02-12-2019-9:52PM: Posted and fixed DL links
      Here is a symbol to get you started:
      @Cheryl_C_Crane Think you requested this,
      RUSTIC BRICK 2.calibz
      Number of Textures: 2
      Map size: 1024x1024
      Filesize: 3.13 MB
    • By mdarch47
      Wondering if anyone with experience storing their Library folders in a Cloud format can share some insight.  Planning to upgrade to X10 soon and believe that would be the way to go.  I run Chief from multiple locations, home office PC, Laptop and a second license with a remote helper.  Ideally I would be able to access the same Library files and only have to update a single location.  I have a OneDrive account with plenty of Cloud storage space.  Any advice is greatly appreciated.
