Glass shower piercing adjoining wall
BlueTree
Do you mean the break in the wall covering in the shower ?   Everything else seems to be able to be fixed with the Intersections tool.
You also have an irregular wall offset beside the tub between the painting and window.
I noticed they're no slop in the shower and no means to keep water from pouring over the wood floor.  Hope this is "in progress" ;)
Also, in PBR, the glass shower walls and door are totally transparent, in both PBR and standard views, even if the definition is tempered glass.  The reflection is not  realistic as the walls are invisible. Is it just me?
I seem to remember in previous versions that tempered showed a slight tint in standard view at least.
Yes that threw me off as well and I thought it was standard glass until I checked.  Not totally transparent but certainly not how I remember it from before.
