Lime Wash
Stevenplane
9 minutes ago, Stevenplane said:
I tried Googling and searching the Knowledge Base to no avail.
How can I get a limewash to display on my brick layer in 3D view?
Thanks in advance!
Check the ticker for "blend with texture" in the brick mat'l dbx under the "texture" tab -would be the might-be-good-enough solution. Alternatively I could build you some good reflection, bump, normals, and ambient occlusions maps. Have an image of what you're looking for
4 minutes ago, Stevenplane said:
Half assed/good enough is good enough ;-)  I'll give it a shot.
I'm just trying to do an as built of a historic home I'm bidding a rehab on.
Built in 1835!
Ha, I removed that line...but appreciate the candor. I can probably make something pretty phenomenal for you.. gonna give it a shot..stay tuned
