.DWG export question
amddrafting
So it was either version X8 or X9 I was having issues with line weight information exporting to a .DWG file when trying to export a plan to send to an architect.
Has this issue been resolved with X10?  Does anyone have autoCAD or a version that can import .DWGs that can verify that I'm not the only one that has had this issue or can anyone just answer that this is CA's standard M.O.?  Thanks in advance.
Thanks, I'll check it out.  I was unaware that the information didn't export until the architect responded after I sent his detail back and he was furious that all of his line weight information had disappeared.  All line weight colors and thickness import correct into CA but I've been unable to figure out how to get it to retain the information during export.
