Contemporary hose wall and roof connection
Aqua76
Hi there!
I am having hard time to model the attached contemporary house. I am try to model it with steel framing. It is impossible to connect wall and roof seamless.
Any advice or tutorial highly appreciated.
thank you.
Seko
Have you tried doing the walls as a gambrel roof?
I set the pitch of the lower roof at 89 degrees (CA doesn't allow a 90 degree pitch).  You will probably have to  experiment with it a little bit and fool around with baseline, ridge, and fascia heights, but you can still come close.  Good Luck!
Steve
16 hours ago, rlackore said:
Maybe I misunderstand the intent, but I think it can be done with normal roof planes: roof.plan
roof1.thumb.PNG.c5aaf07e50825c25ab0b3fcbb1bb0513.PNGroof2.thumb.PNG.691e8847391d95ebbaca2d09831f4b6b.PNGroof3.thumb.PNG.97aa3e44d72832b4404a2728c45c374a.PNG
Did you do it with automatic settings?
Could you please send me the details of this set up?
thank you for your help!
appreciated!
4 hours ago, Aqua76 said:
COuld you please post x8 version.
No, sorry. I'm on X10, and I don't keep previous versions of the software installed on my machine. I suggest you fill out your signature with the version of Chief you are using - that way I would have known from the start that you were running X8. Anyway, maybe these roof settings will help:
1.general.thumb.PNG.ac36191e3f4549da476c1876fc0b8a72.PNG2.options.thumb.PNG.474555a9e1993644d95fd0e79749ff26.PNG3.structure1.thumb.PNG.7697fbda70c1e9b45498b315be65d0e8.PNG3.structure2.thumb.PNG.5af424eb2f22fc4fffdfe696837efd8c.PNG3.structure3.thumb.PNG.a87d44058e69fe9a0ed378cfb8bd3bb2.PNG4.materials.thumb.PNG.de947d5fc3afcaba119bd4fb2473729d.PNG
