Roof Return Issue
Handwerk_Arts
I have a file I am working on the has an entry in the center. I have it mostly finished but cannot get the roof return correct. Also the Garage is -12" from the floor grade with mono slab. Every time i move it, it screws up something. Anyone have time to play with it? or can explain what I did wrong? The middle attic wall is floating, and would not generate a return, so I pulled it from one side.
This one is being designed between HD pro 18 and X9
Carson_draft_zip.zip
I dont understand why the roof over that section can't be selected - and yet nothing is locked.
edit
Never mind, i see you are using auto dutch gable settings.  Just make each side have the same baseline height - right now they are different.
