White Line On Wall In Between 1St Floor And 2Nd Floor?
MichaelAngelo
Have you moved any of the first floor walls since you built the roof/ceiling?
The cause may be obvious to more experienced CA users, but not to me... If you don't mind, it is always easier to diagnose a problem if one can view the plan file. Zip the plan file and attach it to a post (close the plan in CA first, otherwise your compressed file will have no data).
did you try manually pulling the upper wall down into the lower and see if it merged properly ?
Kbird:
pulling walls is not recommended
should only be used when "necessary" and with understanding as to why it is "needed"
pulling walls can mess up a plan real quick if not done "properly"
Lew
