change tile size (solved)
Lighthouse
I tried to create a new tile by:
choosing an existing 10x10 tile in "plan materials"
saving a copy renamed 12x24
changing the size to 12x24 (the size shows correctly in the dbx pattern window)
adding to library
then I open room and change floor material to 12x24 tile
still shows up as 10x10 in camera views
what did I miss?
thanks!
18 minutes ago, solver said:
You need to change the texture. Typically done in something like Photoshop.
Eric,
Why use Photoshop?
The texture size can be easily changed on the Texture tab of the material definition dbx.
