Camera symbol in plan won't auto-display name
Christina_Girerd
I'm trying to get the camera symbol in plan view to automatically display the camera's name.  In the Camera Spec dbx, Plan Display tab, I select "Display as Callout" and according to the help file, if I have no text in the "Text Below Line" box, checking "Automatic" will populate that lower line in the callout with the camera's name.  But I can't get it to work.  If I unselect "automatic" and type the name in myself, it shows fine.  I just can't get the Automatic part to work.  Any suggestions?
Think you misread -from help
Quote
Check Automatic to populate the Text Below Line with the layout page Label if the selected view is sent to layout. If no layout page Label is specified, no automatic Text Below Line will be created.
What I posted was also from the current help, after following the link to "camera labels and callouts" to see if there was something missing.
Looks like the first help is incorrect since what is stated in Camera Labels and Callouts is what actually happens and has for some time.
