X10 Layout Scaling
basilbabaa
Anyone used scaling with X10 yet?
in X9 I used to be able to send to layout as "no scale/scale to fit" and grab a corner of an object on a layout to click and drag to change the scale of the object.
Now, grabbing corner handles reshapes the object on the layout page, which is a nice add, but I would still like to be able to drag the scale of an object on a layout page.
Anyone know if there Is any way to still click and drag to dynamically scale objects on a layout?
I had that same question not long ago and Michael helped out but it is a little more complicated than it was before unfortunately.
"You can still do that by placing a point and using Rotate/Resize About Current Point.  Just switch to the RRACP edit mode, place your point, and then use the Resize edit mode (X)."
