deck framing not displaying
ChrisWamahiu
The issue is "Layers" and the fact that there are several "Display Options" Dialogs (Most newer users do not know this fact), there is a different "Layer Display Options" dialog for plan view, Reference Display, and each camera type has its own "Display Options" Dialog. They all look identical but they are certainly not. So you can order "ON" certain layers in plan view, then create a camera view and in the ordered camera view those layer objects you could see in plan view are missing in the camera view. They key to this is knowing that all "Display Options" Dialogs are not the same, Check and you will see that if missing in one "Display Options" Dialog it is simply a matter of finding the offending layer and turning it "ON" in that layer set.
