attaching stairs to framing
crosscutter55
Are you trying to Draw a Stringer ? I assume so.....
easiest way is to Draw a Chief Staircase , Open the DBX and set everything the sizes you need eg the 7 3/8 Riser Height , then take a Cross Section through the Staircase , and using the CAD Line Tool copy over the Outline of the Stringer in the Elevation View , once the CAD lines join up, you can Convert the Polyline to a Polyline Solid and apply the thickness (1-1/2"?) and the desired Material  ( eg Treated 2x ) and then Convert it to a Solid , and move it , copy it etc , to where-ever you need.
I'll attach my practice plan...done in X10
9.thumb.PNG.41bc0860df230a317e6cb6d4bf8b23dd.PNG8.thumb.PNG.3bfacea166f71f0c915a3ee3c07aa0c6.PNG7.thumb.PNG.e45953c3b99eb21b718fbb7b2c84d142.PNG
Stair Stringer Plan.plan
