Hanging Cabinet Door w/Rollers & Track Bar
No1ZZTopfan
Until the suggestion for one is added to an upgrade or next version of CA I decided to make a crude close facsimile of one. Attached are two hardware fixtures for you to use, modify, improve, etc. I have also attached and example that I made on the front of an entertainment center. Three wall cabinets were used on top of three regular base cabinets. On each wall cabinet, open the specification settings, go to Front/Sides/Back and modify #1 Separation from 3/4" to 4". That gives enough space for above and below for the roller. Position the bar in the center of this spacing. Guide Bar is 2" x 7/16". I did not add mounting brackets so it would allow for stretching and not cause issues. Hope you like.
Cabinet Roller Guide Bar.calibz
Cabinet Roller.calibz
  • 1 month later...
