Until the suggestion for one is added to an upgrade or next version of CA I decided to make a crude close facsimile of one. Attached are two hardware fixtures for you to use, modify, improve, etc. I have also attached and example that I made on the front of an entertainment center. Three wall cabinets were used on top of three regular base cabinets. On each wall cabinet, open the specification settings, go to Front/Sides/Back and modify #1 Separation from 3/4" to 4". That gives enough space for
