No1ZZTopfan
Hanging Cabinet Door w/Rollers & Track Bar
Until the suggestion for one is added to an upgrade or next version of CA I decided to make a crude close facsimile of one. Attached are two hardware fixtures for you to use, modify, improve, etc. I have also attached and example that I made on the front of an entertainment center. Three wall cabinets were used on top of three regular base cabinets. On each wall cabinet, open the specification settings, go to Front/Sides/Back and modify #1 Separation from 3/4" to 4". That gives enough space for above and below for the roller. Position the bar in the center of this spacing. Guide Bar is 2" x 7/16". I did not add mounting brackets so it would allow for stretching and not cause issues. Hope you like.
Cabinet Roller Guide Bar.calibz
Cabinet Roller.calibz
    27478
    Oilersfan20
    Oilersfan20
  • Similar Content
    • By nancyscial
      I am trying to show a recessed wall cabinet bottom for inserting a light strip.
      I need to be able to show the bottom of the cabinet recessed up by 1 1/2" with the sides still down. The doors should cover the recess also.
    • By AlisonWD
      Hello,
      I am applying a wood material to kitchen cabinets and the wood grain is going vertical in the doors and horizontal in the drawers.
      I checked the cabinet specifications and it shows only one material for doors.
      How can I do the wood grain the same direction in the doors and drawers?
      Thank you.
    • By thewell
      What happened to the kitchen potracks that Chief used to have?
    • By yoseflab
      I'm new to CA and am trying to figure out why my kitchen cabinet doors seem to display the wrong sizes.
      In the default cabinet settings under "box construction" I have framless full overlay 1/16" reveal cabinet, one would expect that [as an example] a wall door height and width of a wall cabinet 15"W x 30"H should be 14 7/8"W x 29 7/8"H (15x30 minus 1/16" on all sides). Instead under "Front/Sides/Back" it shows 28.5"W x 13.5"W indicating that the reveals are 0.75"!!! This makes it difficult to calculate the doors when making specific/custom modifications.
      What am I missing?
