ChiefQ
24 minutes ago, solver said:
Put an exterior wall there, and mark it Roof Cuts Wall at Bottom.
Or, if you want a wall in the lower area too, use the Lower Wall Type When Split By Butting Roof setting.
I have a feeling you did not try your solution.  If you asked me,  this plan is a bit of a mess,  yet interesting.
1.   He adjusted many of his wall heights manually,  not a good idea unless you know what  you are doing
2.   the wall is not there because his stairs are on top of wall
3.   I think he is missing a staircase from the garage to the next level up.......
This is a relatively complicated model.
