GENERAL DRIVER DOWNLOAD PAGE AT NVIDIA   https://www.nvidia.com/en-us/geforce/drivers/   -----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------   Nvidia has released new Studio Drivers today ( 8-17-2020) as well ..............Version 452.06     https://www.nvidia.com/Download/Find.aspx?lang=en-us#         --------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------   Nvidia has released new Studio Drivers today ( 7-16-2020) as well ..............Version 451.77   News https://www.nvidia.com/en-us/geforce/news/june-2020-nvidia-studio-driver/   Driver Download:   https://www.nvidia.com/download/driverResults.aspx/162469/en-us   -----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------   NEW Nvidia Drivers were released today July 9th 2020 - both Game Ready (GR) and Studio Drivers   Standard - GeForce 451.67 WHQL Game Ready Driver
https://www.nvidia.com/download/driverResults.aspx/162102/en-us   DCH - GeForce 451.67 WHQL Game Ready Driver https://www.nvidia.com/download/driverResults.aspx/162105/en-us   ----------------------------------------------------------------------------------------------------------------------------------------------- The information below may no longer be relavent in 2020 with Drivers having reached Version 451.xx Series now. Links to Older Drivers also removed above as of June 23 2020. ----------------------------------------------------------------------------------------------------------------------------------------------   Possible Fix for those using older Nvidia Drivers Use the 382.05 Drivers   Many seem to have issues with the new Nvidia 388 Series Drivers and Up ( 388.0 /.13/.33 etc)  installed automatically by Windows Update   **edit....... just a note that the new 10 Series Nvidia Cards seem less likely to have these issues , but it's not unheard of.   eg. The mouse cursor disappearing in 3D views and other weirdness seem to be some symptoms in Chief , I was also get Crashes with some sort of DirectX error , in other Programs , as far as I know Chief uses OpenGL not DirectX  (maybe both?) and Chief was not Open when that was happening     One Possible Fix that helped me and a few others is Rolling the Driver back ( re-installing actually) ) to May's Version 382.05 , this Driver is no longer available since this week off the usual Nvidia Drivers Download page , at least for me, the oldest is 385.12 so below are the direct links to the download page for 382.05.   Make sure you get the Correct Version as there is a Notebook/Laptop version too.   Once you have Run the Installer you will also need to disable Windows Update from Updating Hardware Drivers or it will almost immediately re-Update you to to the 388.xx Driver again, more on that below too.   Nvidia Desktop Driver version 382.05  direct download page   http://www.nvidia.com/download/driverResults.aspx/118514/en-us     Nvidia Notebook/Laptop Driver version 382.05  direct download page   http://www.nvidia.com/download/driverResults.aspx/118518/en-us     How to disable Windows 10 Driver Updates   The Full post is over at TenForums ( a great general Win10 Issues Forum) if you'd like to check it out....   https://www.tenforums.com/tutorials/48277-enable-disable-driver-updates-windows-update-windows-10-a.html     But I use the provided .reg files from there as they always seem to work .... I have zipped them and attached them below for easy download , you will need to run the OFF file for now , the ON file is provided so you can easily re-enable it when desired or needed.   Drivers From Win Update Reg Files.zip   And the Instructions from TenForums  ( all Credit to Shawn aka Brink over there for the Tutorial and Files above )  3. To Turn Off Including Driver Updates in Windows Update
A) Click/tap on the Download button below to download the file below, and go to step 4 below.
Turn_off_include_drivers_in_Windows_Update.reg
  4. Save the .reg file to your desktop. (Unzip the File above to a Folder for reuse , if you downloaded it 1st  and double click it from there)
5. Double click/tap on the downloaded .reg file to merge it.
6. If prompted, click/tap on Run, Yes (UAC), Yes, and OK to approve the merge.   It is usually recommended to restart your computer after a Registry Update , so do that before starting Chief again....     If you need to Renable Driver  Updates just use the other Provided file ie..... Turn ON_   To Turn On Including Driver Updates in Windows Update   Turn_on_include_drivers_in_Windows_Update.reg   5. Double click/tap on the downloaded .reg file to merge it.
6. If prompted, click/tap on Run, Yes (UAC), Yes, and OK to approve the merge.   It is usually recommended to restart your computer after a Registry Update , so do that before starting Chief again....   Also if using a Laptop with two Video Cards ( Discrete Graphics ) make sure the Discrete Card is assign to be used in Chief or the HD Titles as Chief does not have a 3D Profile in Nvidia Control panel for example and is not always recognized as a 3D Application. How to below...   https://us.answers.acer.com/app/answers/detail/a_id/46334/~/configure-amd-radeon-switchable-graphics or https://us.answers.acer.com/app/answers/detail/a_id/11575/related/1       Hope this Helps ,   Mick.
    • Upvote
    2
