template(S) missing
mtldesigns
Starting a new design, and like I have always done b4, started it from a temp-plate that I had set up for this specific builder via the File pull down.  I get the popup of "was not found".  So I checked a couple others that came with Chief and that I have not modified and get the same message (see attached).  So I followed the paths to these templates and can open a new plan via this method.  How do I get it to work via the file pull down??
Nothing has changed on how I open a new plan.  I always use the pull down from under the File menu.  And I checked out the preference setting per your recommendations Chop (see below) and it appears correct.  But when I do try to open, I get the not found pop up.  Second attachment.  BUT.. I can manually go into my folder C:\Users\mtlde\OneDrive\Documents\Chief Architect Premier X9 Data\Templates, click on the template and it opens correctly with all the settings.  My third attachment is all the templates via that path.
