Kitchen Cabinet with multiple material
Rossalaki
How can I apply multiple materials to the face of a cabinet? For example, how can I have a white drawer and a black door in the same cabinet?
I have the same issue with cabinet box. For example, I cannot have a box with a white bottom and black sides.
Thank you!
You can achieve the material difference that you are after by deleting the bottom member from the cabinet, and adding a shelf, with zero as its separation height. The shelf material can then be set to whatever you want.
