Ray Trace & Ceiling Color
hrdorlando
Hi All ... just upgraded to Chief Interiors.  Love it.  But having a bit of an issue getting the ceiling color to read correctly in Ray Trace.  Doing a Holiday Inn which requires something other than white on their ceilings for brand I am working on.  I have a floor lamp, night stand lamp and table lamp in the room.  I have put general lighting overhead, but there will be no overhead lights in actuality.  The ceiling is reading dark gray.  Any help will be appreciated.
You may also try changing the ceiling paint material properties to "General" and adding a bit of "Emissivity" to it. Obtaining accurate color reproduction can be tricky, keep in mind that how a color appears is dictated by the light, direct and indirect, that it receives. You may need to add some 3D lights to make sure the ceiling is being sufficiently lit to render correctly.
