Ray Trace has a haze
Electromen
With raytrace going or done - Image Properties - if "use tone mapping" is checked, an exterior can appear hazed in.  We always check interior (otherwise will look harsh), and always uncheck exterior (otherwise appear flat/hazy).
This may or may not be your issue, but worth checking and certainly worth understanding.  Tone Mapping applies some algorithmy stuff that changes your image by trying to do what it thinks is balancing.  Somebody at Chief can 'splain it better.  But if you look at these images, you'll see that it makes a clear difference.
