Allowed Angles - Pitch
Suggestions
I just learned about a feature that has probably been in the program for quite some time... thought I would share, in case others weren't aware.
Did you know you can enter Pitch Values into the Allowed Angles dialog instead of needing to specify degrees?
Simply type the value in this format: "4 in 12"
Chief will convert to degrees for you.
