Wall Material Overhang
GTdraftingdesign
It's not one I have seen before ...bit strange... but I haven't seen a 37" brick ledge before either....   that front wall could be made a Pony wall with the bottom 36" as a copy of the Main wall definition with the rusted metal set as the outer layer ....that way you don't need to use Base cabinets for that....and it's basically all done Auto.
you could of used a Wall Material Region in X9 too or the old standby of a Soffit from the Cabinet Menu with the rusted material applied.
In the wall definition I also noticed you are dimensioning to framing ...is that normal where you are? allowable ? cos it could make a Building too big , like a back yard Office or shed maybe allowed for eg 12'x12' add plywood or osb and you are an inch over requirements...  something to check in your area perhaps, and ply wood is normally Flush to the Foundation line.
