solver Posted August 11, 2017 Share Posted August 11, 2017 I rarely work with stairs, so when I do, I don't mind a bit of extra work to get them correct. Here is the stair, complete for this exercise. Start by placing a 1 click stair in the plan. Note the number of treads. Here I needed 17, and the tread depth is 11". I wanted sections with 8, 4 and 3 treads, and 2 landings. The stairs are 42" wide, so the landings are 42"x42" and 42"x88-1/2" Remove the railings, then set any other options, width etc. Railings are only removed to make the Point-to-Point move easier. Make 2 copies of the stairs and edit them all to have the required number of treads. Draw in any walls, spacing them to accommodate the stairs. Draw and position Polylines the size of the landings (shown in purple). The polylines give the stair sections something to snap to. The polyline needs a break between 2 stair sections attached to a single segment. Use Point-to-Point Move to move each section, snapping to the polyline (landing). Select each Polyline and convert to a Landing, starting at the bottom and working up. Or just place a landing between the stair sections. Using this method, all the pieces are aligned and the correct size when complete. If I think something will change, I make a copy in place of the landing polylines. Deleting the landing frees the stair section and makes for easy changes. Add rails as required. Control Select to select an individual stair section. 2 Link to comment Share on other sites More sharing options...
CJSpud Posted August 15, 2017 Share Posted August 15, 2017 Eric: When the PL's are converted to landings, do they build at the correct elevations? I have just used landings placed at the correct elevations in the past. Great tip. Thanks. Link to comment Share on other sites More sharing options...
solver Posted August 15, 2017 Author Share Posted August 15, 2017 7 minutes ago, CJSpud said: When the PL's are converted to landings, do they build at the correct elevations? Yes. It works just like selecting the landing tool and clicking between two stair sections. Link to comment Share on other sites More sharing options...
CJSpud Posted August 15, 2017 Share Posted August 15, 2017 Thanks Erik Link to comment Share on other sites More sharing options...
solver Posted February 23, 2021 Author Share Posted February 23, 2021 Video showing what I described above. Link to comment Share on other sites More sharing options...
Michael_Gia Posted February 24, 2021 Share Posted February 24, 2021 18 hours ago, solver said: Video showing what I described above. Very nice, but what is your preference for manually creating stringers? Material region or p-solids, or other? Link to comment Share on other sites More sharing options...
