Ipe Decking
James101
What I do is place the picture in a folder. Name the folder what you want and place it in your Chief Architect Premier Data folder under my textures. Then open the program and do a convert textures to materials. It will then place it in your User library and is ready to use.
you have to change the x and y settings for the image.
there are 7 boards at 5 1/2" each so the x would be 7x5.5
the y can be anything that looks good.  96, 120 etc.  it will stretch to
whatever length.  IF it looks too stretched lower the number but that
sometimes makes a repeat of the pattern more visible.  IF things don't look
right based on what I am telling you reverse the x and y settings as the orientation
is opposite.
