solver
Separate Color for Mulls?
When mulling doors/windows, is there a setting for changing the color of the mulls?
This is normal where they match the trim.
This shows them the window color, but could be any color, and trim different.
Material Region used for the trim here.
If you change the default Minimum Window separation to 1/8" on the  general tab of Window Defaults , you can shove the windows close enough together to eliminate the casing (mulls) between the windows , so it looks pretty good.
this is a 4'x8' with a 16"x8' above it and (3) 32" x48" casements mulled....
    27466
    VCeffects
    VCeffects
