File Menu going AWOL
NestNZ
Hi all,
I've just hooked up a second monitor to my laptop, and now the drop down menus from FILE, EDIT, BUILD etc display off the screen (ie when you click on FILE, EDIT etc the menu is off screen). They seem to be offset to the left a certain amount.
To access the menus I need to minimise CA and move to the centre of the screen - a bit of a pain!
I've attached a screenshot showing the problem.
When no plan file is open the menus appear correctly, and when CA is on the original Laptop screen the menus appear correctly too.
The screen with the 'problem' is the 'main display' according to Windows.
I've tried restarting both CA and the laptop to no avail.
Any ideas?
I have only encountered this type of problem on monitors with certain aspect ratios. Some times the display height of the monitor at its default setting is not enough to accommodate the height of the pop/drop down menu and as such some of it is hidden below the bottom of the screen. You may need to change the resolution of the offending monitor or the scaling.
  • 1 month later...
