Show hatch in sections
DBearss
I assume that you are using Auto Detail to generate the insulation hatching.
Auto Detail only works on the currently active  section - it is just a cad that overlays the section.
You need to explain in more detail regarding the incorrect insulation.
Well there you go.
This job was shelved for a bit and I jump back and forth to CA and ArchiCAD so totally forgot what I did. Auto detail it is. Thanks for the reminder.
Also the insulation corrected itself.
Thanks.
