Can't Select Nor Delete a 'Hole' in a Slab - More weirdness
HumbleChief
Not sure what's happening here but I can't delete certain items and now I can't select a hole in a slab in order to delete it. If I insert a new hole I can select and delete it but not the other hole. I can replace the slab easily enough but am just wondering what I'm missing?
Anyone else experiencing this?
Attached plan.
hole_in_slab.plan
6 minutes ago, solver said:
If you convert the slab polyline to a plain polyline, then back to a slab, you can select the slab hole.
Thanks Eric, but what happened? And why should one have to do that? I can always just replace the slab which is essentially what you suggesting but why? There's a couple of buggy things I've encountered with this new release but that doesn't lessen my appreciation for your help and time.
thanks again.
