Small dimensions covering their own line
CRHDesign
Every time I place dimensions, smaller dimensions will cover the line of the dimension with its white box. Is there a way to stop this from happening? Either moving the white box, disabling it, or moving the dimension slightly up?
See the 3 1/2" and 5 1/2" dimensions in the attached picture.
Why are you dimensioning the width of every wall? It is common practice to dimension from the outside face of the framing to the face of the framing when dimensioning a plan. If you are concerned with the Subcontractors being able to differentiate 2x4 and 2x6 wall from each other then use a different hatch pattern for 2x4 and 2x6 walls and create a wall legend.
For cabinet and Interior Deco plans it is common practice to dimension to the inside of the finish layer of the walls.
