Porch Gable issue
Designer100
Randy, this is not a difficult task.
Open your plan
1) Turn the "Roof, Planes " layer on.
2) Connect roof planes
3) Select each plane of this porch gable and set same height as a fascia height of your main roof. In this case it is 110 7/16"
4) Select planes at the ridge and use "2" to connect them.
I am not 100% sure what ceiling you intend to put.
If you check with the room porch DBX.
You ceiling height is set at 169". That will create a nice exposed vault.
If you want a flat ceiling you need to set it to something like 96"
BT
8 hours ago, Designer100 said:
it will not let me change to 110 7/16" and 4:12 pitch. I change one and it changes the other if I lock one?
First lock the pitch and set you fascia height to 110 7/16".
Now lock the fascia height and set your pitch to 4:12.
Practice, practice, practice.
  • 1 month later...
This forum is the best source for quick HELP with Chief Architect and always has been. Scott we all owe you a "thank you" too, you have helped many. I must add this bit of humor, Scott you have also "ticked off" many, lol.
  • Upvote 3
ShaneK
I am with you. There is nothing that makes great than being thankful.
I gave point to Erric.
+1 for your self.
Thanks to Scott. Scott is the best, his tutorials are very nice to follow.
Appreciate the time taken to help others.
