Annotating 3D Perspective Views
Joe_Carrick
If you create a CAD Detail from View of a 3D Perspective (Vector Render) you can then add Text to that View.  The keys to this are:
  1. The 3D Perspective View must be set to Vector Mode
  2. You must create a CAD Detail from View
  3. If you want a Title for the View
    1. Rename the CAD Detail to the name you want the Title to be
    2. use the %view.name% macro
  4. All of the Text Object Types are available in CAD Details
It would be nice if we could create a CAD Detail from View using at least some of the other Render Modes - but that's not available currently.
19 minutes ago, javatom said:
It would be very nice to be able to notate the view without converting it to a cad detail
The problem is that Text is a 2D CAD Object and even if we could add text to a 3D Perspective the text would not rotate with the View.
You can of course send an Image of the 3D Render to Layout and then superimpose the text in the Layout.
