Opening Indicators in X9 showing shadows
VHampton
  • 1 month later...
Any luck with the shadow issue.  Im having the same issues in layout.  It starts out normal and then as I go back and forth it changes to this  Not sure if its me or chief?
This was not an upgrade issue it seems.
It turns out that a far away object in the plan view can cause shadow glitches on the model.
The only remedy is to search out whatever is off by its lonesome on the far reaches of the drawing.
