Cased opening where the casing and frame terminate on a counter instead of the floor.   Place Doorway and adjust as needed -- width, casing profile, etc.   Copy wall containing Doorway to a new plan. Adjust the height of the Doorway. In a Camera View, use the Delete Surface tool to remove the wall surfaces, leaving the casing and frame.   Convert to Symbol and add to Library.
    • Upvote
