solver Posted February 26, 2017 Share Posted February 26, 2017 Cased opening where the casing and frame terminate on a counter instead of the floor. Place Doorway and adjust as needed -- width, casing profile, etc. Copy wall containing Doorway to a new plan. Adjust the height of the Doorway. In a Camera View, use the Delete Surface tool to remove the wall surfaces, leaving the casing and frame. Convert to Symbol and add to Library. 1 Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 26, 2017 Share Posted February 26, 2017 That's a super good tip with a lot of possible uses Eric. Thank you. Link to comment Share on other sites More sharing options...
