Some painted cabinets are transparent - why?
J_Ward
1 minute ago, Joe_Carrick said:
Edit that material's properties.  Currently the transparency is 12%.
ps: I prefer to assign the color in the cabinet dbx rather than using the "Paint" tool.  It provides much better results
2
That's interesting. I've never done it that way. What is the advantage? While I haven't looked side by side, my color in the dbx box shows the correct color that I painted it with.
Using "Paint" adds extra words to the material finish.  Depending on the underlying material and other settings, it can result in a blending of the colors.  Using the dbx actually results in a replacement rather than an extra - and as you see in your plan, a potential for unexpected results.
Only if you use the blender option (paint roller) using the material painter places the color.
I checked the color from the BM catalog and it is fine OOB, so not an X9 thing. Must be some other cause for the transparency.
