Why I hesitate to cusomize CA ussing Macros
OkcDesigner
Image 2 from PDF of printed and delivered plan last Friday window label correct. Then then Image 1 how that plan changed thanks to the new release of CA.
I have better things to do than go back and fix what was not broke, and now is!!!!!!!!!!!!!!!!
Window label macro not working like it did on Monday..... Fingers crossed that my little area of their sand box big enough to get fixed.......before XL
Before you ask, I can not send in Macro, it is another sandbox playmate's, I bought and modified..............
unfortunately, new releases can cause things to go bump in the night
best to inform CA's tech support as they try to minimize these "bumps"
while I advocate that most of Chief's tasks be doable without macros
the use of Macros can be very handy and "powerful"
my last career job involved heavy use of macros and editing them was part of the job
Lew
Marc,
Replace all instances in your macros of
  owner.top_elevation
with
  (owner.header_elevation-owner.rough_opening_top)
The problem is that X9 fails to initialize the top_elevation and bottom_elevation attributes.  I reported this to Brian at CA and he acknowledged the problem.  It's in their court to fix it but in the meantime, using the above alternative solves the problem.
